I can get my Lime USB to work, for a little while, but it inevitable fails then needs to be cold started.
Is it defective?
It’s been updated: Firmware is 4, Gateware is 2.18.
USB is 3.0 with external 12V, 2A supply.
Heatsink kit has been applied.
In Pothos, running simple_fm_demod, CPU is below 30% , then I get:
[04:28:04.177000] SoapySDR: Read(64 bytes) failed
[04:28:04.201000] SoapySDR: SetFrequencySXR(101 MHz) - cannot deliver frequency
[04:28:04.829000] SoapySDR: SetFrequencySXR(101.9 MHz) - cannot deliver frequency
[04:28:05.183000] SoapySDR: SetFrequencySXR(101.9 MHz) - cannot deliver frequency
Then, if I try to use Suite, on connecting I get:
[20:29:43] WARNING: Gateware version mismatch!
Expected gateware version 2, revision 18
[20:29:43] INFO: Reference clock 30.72 MHz
[20:29:43] INFO: Connected Control port: LimeSDR-USB FW:4 HW:0 Protocol:1 GW:0.0 Ref Clk: 30.72 MHz
Then Quicktest gives:
->Start time: Wed Jan 23 20:31:46 2019
Expected gateware version 2, revision 17
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=0009060B00491E2B, index=0
Serial Number: 0009060B00491E2B
->FX3 GPIF clock test
Test results: 1; 0; 0 - PASSED
->Si5351C test
CLK0: 2 / 17554 - FAILED
CLK1: 2 / 17554 - FAILED
CLK2: 2 / 17554 - FAILED
CLK3: 2 / 17554 - FAILED
CLK4: 2 / 17554 - FAILED
CLK5: 2 / 17554 - FAILED
CLK6: 2 / 17554 - FAILED
FAILED
Results : 4 (min); 4 (max) - FAILED
FAILED
->ADF4002 Test
Error
FAILED
->Clock Network Test FAILED
->Read data: 11 02 14 11 02 14 02
->FPGA EEPROM Test PASSED
RegistersTest() failed
->LMS7002M Test FAILED
SetFrequencySXT(1250 MHz) - cannot deliver frequency
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 0.93 seconds
