I need complete tutorial to setup limesdr. I already found basic driver installation tutorial. I installed drivers and limesuite. I also found out that limesuite recognized limesdr. After that I don’t know how to use it so I’m bit confused. I know I need to calibrate it, test loop back and choose channels and stuff. Of course all after driver install is unkown to me.
So I’m am asking complete tutorial untill I end up to sdr console v3 or hdsdr whatever.
Hi. I chose to build all the components from source and (generally) followed the steps from this page http://blog.reds.ch/?p=43
To ease the installation process, I skipped creating the source and install folder trees, so basically I just used cmake … without the -DCMAKE_INSTALL_PREFIX lines.
I ended with a working version of gqrx. After that, I compiled and installed sdrangel from github and now my limesdr mini works with RX and TX.
Same Here!! Limesuite doesn’t make sense for use with the mini, I really would have rather purchased the regular LimeSDR for $599 then this Mini for 299.99 that just heats up to 130deg in it’s small metal case that came with it.
Well mini is well hmm, mini. Try sticking raspberry pi heatsinks to it. Even bigger limesdr heats up a bit before even using it (well still no idea how to use it!). But tutorial would be nice!
