I’m getting a twin-peak pattern on many bands that I’ve tested on the Lime SDR Mini. I’ve tried different bandwidths and with enough fiddling with the frequency setting (clicking on the waterfall) it will sometimes go away and be normal again. I’m using SDR Console and have noted this on that board. Maybe it is a bad setting somewhere.
The Lime SDR Mini is deaf when I get the twin peaks and they even appear with no antenna connected.
I need to try another SDR program if I can get another one working.
Any thoughts in the interim would be welcome. Simon advised he would look at it some time this week as well.
I was going to say that I’m not sure what the current status is with SDR Console, in that if device gateware is updated it may need updating also — or at least linking against a new version of Lime Suite. But sounds like you’re in touch with Simon, which is good.
You might like to also give SDRangel a try. @martywittrock is a big fan and there are quite a few of his posts on here where he’s assisted others in getting up and running.
Ahh! I see whats up.
I also get that one but it is a mixing product from an outside unidentified source.
If you use a band pass filter does it go away?
On my setup that same noise was laying waste to the noise floor on the Marine and aviation bands, would come and go and occasionally move around.
Adding marine and air band filters made it disappear in those bands, you of course would want to use filters for whatever band you are listening to or watching to get the same relief.
I tested it in the mobile and on the mobile laptop (different computer) and had the same result.
A filter hasn’t helped as it still occurs with no antenna connected as well. I’m going to test another desktop again.
If I could get Gqrx (I think it is) working, I could test another program. It doesn’t give me a waterfall on Windows. I’m going to try setting up a virtual Linux machine as well. I haven’t figured out SDRAngel yet, but read it doesn’t work with Windows with the Lime Mini. Maybe the same problem plagues Gqrx.
I still can’t get Gqrx to work with the Lime Mini. It works fine with the SDR Play 2. Is the Lime Mini not supported? I’ve fiddled with many settings to no avail.
->REF clock test
Test results: 11262; 24459; 37656 - PASSED
Results : 6711109 (min); 6711270 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 06 1D 12 06 1D 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
Then I’m back to my original question of why does it have the problem when I change frequencies. Something is wrong. Did you see the above screen cap with the twin peaks?
