I am running a Raspberry Pi 4 B 8GB with 128GB mini SD-Card
I have updated this post with quicktest results, and changed topic to LimeSDR.
In https://wiki.myriadrf.org/LimeSDR_Firmware_Management it is stated that it is important to update the firmware, and that this shall be performed using the command:
LimeUtil --update
LimeUtil --update gives the error message:
jon@la6cda:~ $ LimeUtil --update
Connected to [LimeSDR Mini [USB 3.0] 1D53882739A85F]
Invalid image file
Programming update failed!
LimeUtil --info gives:
jon@la6cda:~ $ LimeUtil --info
LimeSuite information summary
Version information:
Library version: v20.01.0-gc931854e
Build timestamp: 2020-07-17
Interface version: v2020.1.0
Binary interface: 20.01-1
System resources:
Installation root: /usr/local
User home directory: /home/jon
App data directory: /home/jon/.local/share/LimeSuite
Config directory: /home/jon/.limesuite
Image search paths:
- /home/jon/.local/share/LimeSuite/images
Supported connections:
- FT601
- FX3
- PCIEXillybus
jon@la6cda:~ $ LimeQuickTest
->Start time: Sat Oct 24 08:06:19 2020
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D53882739A85F
Serial Number: 1D53882739A85F
->REF clock test
Test results: 36166; 49365; 62560 - PASSED
Results : 6711037 (min); 6711203 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 07 0C 13 07 0C 03
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-14.3 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-14.0 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 2.54 seconds
So, the QuickTest passes, and still the update is failing.
Is there anything wring with the card?
