So, I’m trying to do a comprehensive report of the transmit characteristics of the LimeSDR USB (which is fine and running great - information shows up in the forum on that) and the Lime Mini (that has somehow taken a dive since the last time I used it in November). I started out checking it out on SDRAngel and it wasn’t recognized in the list (driver is good - I checked that in LimeSuite). So I decided to try to program the Lime Mini and it just hung in LimeSuite. LimeSuite can see my Mini, but it just hangs there and does not program. Yes, I am using USB 3.0 - I won’t use anything else on any SDR other than RTLs that I don’t even play with anymore since I’ve had the Limes.
So I decided to reset everything - including my i7 desktop PC - and try LimeSuite again - this time fetching the DeviceInfo. Here are the stats on that:
Device: LimeSDR-Mini
Expansion: UNSUPPORTED
Firmware: 5
Hardware: 0
Protocol: 1
Gateware: 1.18
Gateware Target: LimeSDR-Mini
So then I found the Lime Mini Quicktest and everything ran great until I got to the RF Loopback part of the test, where it failed on a SetPllFrequency: where Bit 1 was still busy.
So, at this point, what do I have…? Do I have a good Mini that just needs to be reprogrammed differently, or do I have a mighty fancy doorstop? Specs of the QuickTest are below for your inspection - please let me know where I am on this.
@Zack @IgnasJ - Any comments on this you can share with me about what’s happening with my Lime Mini…? Please let me know
Thanks es 73 - de Marty, KN0CK
Lime Mini QuickTest data follows:
->LMS7002M Test PASSED
SetPllFrequency: timeout, busy bit is still 1
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 10.07 seconds
->Start time: Sun Feb 24 16:28:57 2019
->Device: LimeSDR Mini, media=USB 3, module=FT601, serial=1D35488A5FC822, index=0
Serial Number: 1D35488A5FC822
->REF clock test
Test results: 22940; 36138; 49335 - PASSED
Results : 6710956 (min); 6711117 (max) - PASSED
->Clock Network Test PASSED
->Read data: 11 0B 03 11 0B 06 03
->FPGA EEPROM Test PASSED
Elapsed time: 9.93 seconds
