#include <LMS7002M/LMS7002M.h>
#include <LMS7002M/LMS7002M_logger.h>
#include "spidev_interface.h"
#include <wiringPi.h>
#include <unistd.h>
#include <stdlib.h>
#include <LMS7002M_filter_cal.h>
#include "mcu_dc_iq_calibration.h"
#define REF_FREQ (50e6)
#define PROGRAM_BUFF_MASK 1<<0
#define PROGRAM_COMP_MASK 1<<6
#define SPI_CONTROL_MCU 1<<0;
#define IMAGE_SIZE 16384
//set the time interval of delay in seconds
int LMS_GPIO_LOW = 2;
int LMS_GPIO_HIGH = 2;
int LMS_CONFIGURABLE = 1000;
int DELAY = 30000;
//CALIBRATION defines
enum CALIB {
TX_CHAIN = 1,
RX_CHAIN = 2,
BW_UPDATE = 3,
CLK_UPDATE = 4,
RX_FILTER = 5,
TX_FILTER = 6,
MCU_IMAGE_ID = 255
} calib_proc;
LMS7002M_t *lms;//Make LMS instance glLMS7002M_t *lms;//Make LMS instance global to prevent stack overflow while passing to functions
void run_calib_procedure(int proc_id) {
int value = LMS7002M_spi_read(lms, 0x0006);
value |= SPI_CONTROL_MCU;
LMS7002M_spi_write(lms, 0x0006, value); //switch SPI control to MCU
LMS7002M_spi_write(lms, 0x0000, 0x01); //run TX chain calibration
value = LMS7002M_spi_read(lms, 0x0002);
value &= ~(1 << 3);
LMS7002M_spi_write(lms, 0x0002, value); //reset the 3rd bit of 0x0002
value |= (1 << 3);
LMS7002M_spi_write(lms, 0x0002, value); //set the 3rd bit of 0x0002
value &= ~(1 << 3);
uint8_t status = LMS7002M_spi_read(lms, 0x0001) & 0xff;
//TODO:Add timeout here
while (status == 0xff) {
};//wait till calibration is in progress
if (status == 0x00)
printf("Calibration complete successful\n");
else
printf("Calibration failed.\n");
value &= ~SPI_CONTROL_MCU;
LMS7002M_spi_write(lms, 0x0006, value); //give back control to the BB processor
void update_BW_or_clock(uint8_t kHz_LSB, uint8_t kHz_MSB, uint8_t MHz) {
LMS7002M_spi_write(lms, 0x0000, kHz_LSB);
int value = LMS7002M_spi_read(lms, 0x0002);
value |= (1 << 2); //set the second bit
value &= ~(1 << 2);
LMS7002M_spi_write(lms, 0x0002, value); //reset the second bit
LMS7002M_spi_write(lms, 0x0000, kHz_MSB);
value &= ~(1 << 2);
LMS7002M_spi_write(lms, 0x0000, MHz);
value &= ~(1 << 2);
int main() {
LMS7_set_log_level(LMS7_DEBUG);
//initialize wiring pi
wiringPiSetup();
pinMode(6, OUTPUT);
//create an SPI handle
void *handle = spidev_interface_open("/dev/spidev0.0");
if (handle == NULL) {
printf("\nUnable to create the handle . Exiting . ");
return -1;
//create an object
lms = LMS7002M_create(spidev_interface_transact, handle);
if (lms == NULL) {
printf("Unable to create the LMS7002M interface . ");
return -1;
// LMS7002M_reset(lms);
//read from the SPI device
digitalWrite(6, LOW);
delay(LMS_GPIO_LOW);
digitalWrite(6, HIGH);
//delay(LMS_GPIO_HIGH);
//delay(LMS_CONFIGURABLE);
//usleep(DELAY);
usleep(DELAY);
LMS7002M_set_spi_mode(lms, 4);
usleep(DELAY);
LMS7002M_regs_spi_read(lms, 0x002f);
usleep(DELAY);
printf("rev. 0x%x\n", LMS7002M_regs(lms)->reg_0x002f_rev);
printf("ver. 0x%x\n", LMS7002M_regs(lms)->reg_0x002f_ver);
LMS7002M_spi_write(lms, 0x0002, 0x0000); //reset the MCU
usleep(DELAY);
LMS7002M_spi_write(lms, 0x0002, 0x0002); //select EEPROM/SRAM Mode .Works for mode 0x0001(EEPROM and SRAM)
int value = LMS7002M_spi_read(lms, 0x0003); //read programming buffer register
uint8_t *fp = (uint8_t *)calib_bin;
//TODO:ADD timeout here
while ( (value & PROGRAM_BUFF_MASK) == 1 ) { //loop if program buffer is not empty
printf("Program buffer not empty\n");
//printf("Out of while loop");
printf("================Ready to flash the image======================\n");
int size = 16384;
//write the binary into the MCU
//NOTE:The size of binary is 16384,so total writes in steps of 32 are 16384/32=4096
uint16_t data = 0;
for (int i = 0; i < IMAGE_SIZE; i += 4) {
data = (0x00 << 8) | fp[i];
//printf("%x\t",data);
LMS7002M_spi_write(lms, 0x0004, data);
data = (0x00 << 8) | fp[i + 1];
data = (0x00 << 8) | fp[i + 2];
data = (0x00 << 8) | fp[i + 3];
//usleep(1);
//printf("%d",i);
//printf("Waiting for the Program buffer\n");
//usleep(1);
usleep(1);
while ( (value & PROGRAM_COMP_MASK) == 0 ) {
printf("Programming not complete\n");
usleep(1);
printf("=================Programming complete===============================\n");
printf("=================Running image calibration==========================\n");
//NOTE:clk and bandwidth parameters must be passed before any other calibration
printf("Updating reference clk rate\n");
update_BW_or_clock(0xd0, 0x02, 0x1e); //30.72 MHz reference clock
calib_proc = CLK_UPDATE;
run_calib_procedure(calib_proc);
printf("Updating bandwidth\n");
update_BW_or_clock(0x0, 0x0, 0x05); //5 MHz bandwidth
calib_proc = BW_UPDATE;
run_calib_procedure(BW_UPDATE);
printf("Doing TX chain calibration.\n");
calib_proc = TX_CHAIN;
printf("Doing RX chain calibration\n");
calib_proc = RX_CHAIN;
printf("Doing RX filter calibration\n");
calib_proc = RX_FILTER;
printf("Doing TX filter calibration\n");
calib_proc = TX_FILTER;
spidev_interface_close(handle);//close the handle
@Zack this is my code
