Hi all,
I’m trying to lower the latency when transmitting at once. It seems that setting latency to 0 or 1 doesn’t change anything. If I set bufferLength to 54400 (ie 1360 * 40, I’m using SC12) and I pass my signal by chunks of 55400 samples, then my signal is sent faster. I gain ~200µs.
The problem is that now when I schedule a transmit, it seems that I can’t pass all the samples at once. Before, passing the samples to the Lime would take maybe 0.3ms, while now it takes ~11ms, knowing that I schedule the signal ~11ms in advance. I guess a fixed number of buffers is available somewhere, and they fill up faster as I set them to have a smaller size. As a result the call to SoapySDRDevice_writeStream ends up blocking.
I don’t know if this is linked to Soapy or Lime, nor if it’s in the C++ or FPGA part. Maybe @joshblum , @Zack or @IgnasJ can shed some light?
I would like to have the smallest latency when transmitting at once, while still being able to schedule signals without blocking as much as possible.
Thanks.
