Good morning! I*m working on a project using LimeSDR device. During my field experiment i got a problem. I am able to see the signal of my radiostation[462,225 MHz] just within 50 meters, after that the signal disappears. And every few steps its level significantly decreases. I decided that it is because of device gains. When i tried to regulate gain - it only worked for channel A. When i looked through the API, i found out that PGA(0x0119) LNA TIA gains are set to 0x0113. Looking through LMS7002 Params i found out that there was no address for the 2nd channel. Or maybe i don’t understand smth. The question is how can i tell the device to set gain to Channels A&B simultaneously?
My guess is i have to add registor address here :
public LimeSDRDevice()
_gcHandle = GCHandle.Alloc(this);
dataMutex = new Mutex();
PGA_gain.address = 0x0119;
PGA_gain.msb = 4;
PGA_gain.lsb = 0;
PGA_gain.defaultValue = 10;
PGA_gain.name = "G_PGA_RBB";
PGA_gain.tooltip = "This is the gain of the PGA";
// + the same for 2nd channel
TIA_gain.address = 0x0113;
TIA_gain.msb = 1;
TIA_gain.lsb = 0;
TIA_gain.defaultValue = 6;
TIA_gain.name = “G_TIA_RFE”;
TIA_gain.tooltip = “Controls the Gain of the TIA”;
LNA_gain.address = 0x0113;
LNA_gain.msb = 9;
LNA_gain.lsb = 6;
LNA_gain.defaultValue = 21;
LNA_gain.name = “G_LNA_RFE”;
LNA_gain.tooltip = “Controls the gain of the LNA”;
CMIX_BYP_RXTSP.address = 0x040C;
CMIX_BYP_RXTSP.msb = 7;
CMIX_BYP_RXTSP.lsb = 7;
CMIX_BYP_RXTSP.defaultValue = 0;
CMIX_BYP_RXTSP.name = “CMIX_BYP_RXTSP”;
CMIX_BYP_RXTSP.tooltip = “CMIX bypass”;
If i am right, please , give me its registor address . If not, please, advice me how to fix it. Thank you!
