Hi, I’m trying to use LimeSDR to debug a signal by transmiting an IQ signal from LimeSDR to a HackRF.
The signal seens weird in reception. For example this is the IQ I’m transmiting:
And this is how I’m receiving with HackRF
The system are connected through cable. This is my GRC flow:
Any ideas why it’s not transmitting right?
This is the log:
Generating: '/media/ELTN/Baseband Records/GOES/GRB/top_block.py'
Executing: /usr/bin/python -u /media/ELTN/Baseband Records/GOES/GRB/top_block.py
linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_003.010.002.000-release
gr-osmosdr v0.1.4-95-g34456aff (0.1.5git) gnuradio 3.7.10
built-in sink types: uhd hackrf bladerf soapy redpitaya file
[INFO] Make connection: 'LimeSDR-USB [USB 3.0] 9062000C5170C'
[INFO] Estimated reference clock 30,7198 MHz
[INFO] Selected reference clock 30,720 MHz
[INFO] Reference: 30,72 MHz
[INFO] Init LMS7002M(0)
[INFO] Ver=7, Rev=1, Mask=1
[INFO] LMS7002M cache /home/lucas/.limesuite/LMS7002M_cache_values.db
[INFO] Rx Filter calibrated from cache
[INFO] Tx Filter calibrated from cache
SetFrequency using cache values vco:1, csw:213
Tx calibration values found in cache:
| DC | GAIN | PHASE
I: | 819 | 1977 | -2
Q: | 10 | 2047 |
[+] Selected device: GeForce GTX 980M
Thanks,
