Hi all,
It seems that when scheduling a signal to be transmitted at a specific timestamp, if the TX sampling rate is different from the RX sampling rate, the duration of the transmitted signal may be incorrect.
For example, I’m in SISO, RX is at 55MS/s and TX is at 55MS/s or 55/2. The duration of the transmitted signal is fine, whether I send it at once or I schedule it.
But then if TX is at 55/4, 55/8 or 55/16 MS/s, then when scheduling the signal, I see that the duration of the transmitted signal gets shorter and shorter. From a signal that should be ~2.2ms, I end up seing a signal lasting ~1.8, ~1.4 and ~1ms respectively.
With the same code (using Soapy), if I transmit the signal at once, it is always of the correct duration, no matter the TX sampling rate.
@IgnasJ @Zack Is that a know bug or limitation?
Thanks.
