Dear All,
I am using 4 LIMESDR-USB’s in a system (2 are TX and 2 are RX only).
I am programming them using the LIME API functions. (dll version is 19.04)
I suspect the PLL’s are not locking (for SXR).
The VCO tunes fine for the selected frequency but the “failed to lock” indication never disappears.
Here is the debug output:
[17:10:35] DEBUG: Estimated reference clock 30.6589 MHz
[17:10:35] INFO: Reference clock 30.72 MHz
[17:10:35] INFO: Connected Control port: LimeSDR-USB FW:4 HW:4 Protocol:1 GW:2.21 Ref Clk: 30.72 MHz
[17:10:57] DEBUG: INT 68, FRAC 948906, DIV_OUTCH_CGEN 3
[17:10:57] DEBUG: VCO 2147.48 MHz, RefClk 30.72 MHz
[17:10:57] DEBUG: csw 108; interval [105, 111]
[17:10:57] INFO: CGEN frequency set to 268.434998 MHz
[17:10:59] DEBUG: csw 108; interval [105, 111]
[17:11:10] DEBUG: INT 146, FRAC 211899, DIV_LOCH 5, EN_DIV2_DIVPROG 0
[17:11:10] DEBUG: VCO 4614.21 MHz, RefClk 30.72 MHz
[17:11:10] DEBUG: ICT_VCO: 192
[17:11:10] DEBUG: csw=64 cmphl=0
[17:11:10] DEBUG: csw=96 cmphl=0
[17:11:10] DEBUG: csw=112 cmphl=0
[17:11:10] DEBUG: csw=120 cmphl=0
[17:11:10] DEBUG: csw=124 cmphl=0
[17:11:10] DEBUG: csw=126 cmphl=0
[17:11:10] DEBUG: csw=127 cmphl=0
[17:11:10] DEBUG: Failed to lock
[17:11:10] DEBUG: csw=192 cmphl=3
[17:11:10] DEBUG: csw=160 cmphl=0
[17:11:10] DEBUG: csw=176 cmphl=3
[17:11:10] DEBUG: csw=168 cmphl=2
[17:11:10] DEBUG: csw=172 cmphl=2
[17:11:10] DEBUG: csw=174 cmphl=3
[17:11:10] DEBUG: csw=173 cmphl=3
[17:11:10] DEBUG: cmphl=2
[17:11:10] DEBUG: VCOL : csw=170 tune ok
[17:11:10] DEBUG: TuneVCO(SXR) - VCO too high
[17:11:10] DEBUG: VCOM : csw=0 tune fail
[17:11:10] DEBUG: VCOH : csw=0 tune fail
[17:11:10] DEBUG: Selected: VCOL
[17:11:10] INFO: SXR frequency set to 72.097000 MHz
[17:11:17] DEBUG: ICT_VCO: 192
[17:11:17] DEBUG: csw=64 cmphl=0
[17:11:17] DEBUG: csw=96 cmphl=0
[17:11:17] DEBUG: csw=112 cmphl=0
[17:11:17] DEBUG: csw=120 cmphl=0
[17:11:17] DEBUG: csw=124 cmphl=0
[17:11:17] DEBUG: csw=126 cmphl=0
[17:11:17] DEBUG: csw=127 cmphl=0
[17:11:17] DEBUG: Failed to lock
[17:11:17] DEBUG: csw=192 cmphl=3
[17:11:17] DEBUG: csw=160 cmphl=0
[17:11:17] DEBUG: csw=176 cmphl=3
[17:11:17] DEBUG: csw=168 cmphl=2
[17:11:17] DEBUG: csw=172 cmphl=2
[17:11:17] DEBUG: csw=174 cmphl=3
[17:11:17] DEBUG: csw=173 cmphl=3
[17:11:17] DEBUG: cmphl=2
