Hi
The examples are running correctly but the GNU plot is totally ineffective.
The related code is executed but nothing appears.
Is it normal with windows?
Thank You
Pietro
Hi
Thank You
Pietro
Nobody want to answer?
The version of gnuplot found at -
http://tmacchant33.starfree.jp/gnuplot_bin.html
works just fine with the “animate” example on Widows 10.
Hei
Fine to have your experience, I installed the latest version and in itself works. But no plot appears during the run.
If You have suggestion, just welcome.
Pietro
Thank You
