I seem to have a strange issue with LimeSDR. When I try to get GPS IF IQ data out, the IQ data doesnt seem to change at all. I tried collecting it from Pothos, used GNSS_SDR and then finally tried with SoapySDR api’s.
The parameters are like this -
Center frequency - 1575.42MHz
Bandwidth - 2.048MHz
Sampling Frequency - 4.096MHz
Gain - 60dB
The value doesnt change whether I use an active antenna or whether I use a passive antenna.
Can I get a replacement board of LimeSDR?
There are three gain controls used with the LimeSDR and when I used them for GNSS_SDR using Ubuntu I set them to the following settings:
PGA = 31
LNA = 15
TIA = 2
The full disclosure on how to get your LimeSDR to play on GPS is at the following link:
I would highly recommend that you read ALL the threads on that page even if you’ve played with GNSS_SDR already. There’s a TON of information how all of us got it working with the LimeSDR and it really plays fine with it…!
Hi Marty,
Thanks for the inputs. I have tried all these mentioned in the forums. Finally I wanted to see if there was any toggle in the IQ data as the histogram was completely biased (also the range was not in the space of +/-1), To which I found that IQ data had this kind of a plot for which I didnt find any explanations.
