I am new to limesdr. My task is to read IQ data using limesdr. While exploring I found that file sink is used to capture the IQ data. So I used File sink block in my flowgraph. After running the flowgraph, some data are written in the file but which are not readable characters.
IQ data is just raw waveforms, if you direct the output of LimeSDR source into File sink, the data is not going to have any meaning that could be read as a character string.
The file is just going to contain raw binary data, which also depends on which output format you choose, floating point numbers, or integers.
You gave me the example graph, so now i need to add the file sink with the block or what I have to do?
can you explain me how to achieve this IQ data capture with limesdr mini?
I don’t understand your goal, if you wanted to just capture the IQ data, then you already have done it with the File sink block. Here’s what it looks like:
What do you expect to see in the file? The data is binary, it’s not going to be human readable. The data inside the file is just binary sequence of floating point numbers (4 bytes each), one IQ sample is two numbers.
I looked at all of the gnuradio blocks - there does not appear to be a simple timer. Gnuradio actually creates a python program which it then runs. You can call the Gnuradio routines from python - so you could create a python program to do what you want or you could build an OutOfTreeModule to add a timer function to gnuradio. Another possibility would be to use UDP or TCP/IP to pass the I/Q data to an extern program to do the timing for you. As an example -
Thanks for your assistance. I have made two push buttons start and stop and I have made some modifications in the code generated by gnuradio to record until I press stop. Now its working fine.
