I’m wondering what the correct process is to update the LimeSDR Mini? I’ve had a search around and haven’t found any documentation yet - which is fair enough for a pre-production board
I’ve tried some LimeUtil options but no luck:
$ LimeUtil --update
Connected to [LimeSDR Mini [USB 3.0] 1D3548B7BA5942]
Programming update failed! : ProgramUpdate not supported
$ LimeUtil --fpga=LimeSDR-Mini_lms7_trx_HW_1.0_auto.rpd
[ 0%] 0/577536 Bytes Programming failed! Write operation failed
Programming failed! : Programming failed! Write operation failed
and in dmesg:
[24900.820190] usb 4-1: usbfs: process 11699 (LimeUtil) did not claim interface 0 before use
I also tried to use the Programming window in LimeSuite, but that fails too.
I’m using Ubuntu 16.04, everything built from git via pybombs, and LimeUtil info:
$ LimeUtil --info
Version information:
Library version: v17.10.0-g655ae786
Build timestamp: 2017-12-14
Interface version: v2017.10.0
Binary interface: 17.10-1
System resources:
Installation root: /home/mike/gnuradio
User home directory: /home/mike
App data directory: /home/mike/.local/share/LimeSuite
Config directory: /home/mike/.limesuite
Image search paths:
- /home/mike/.local/share/LimeSuite/images
- /home/mike/gnuradio/share/LimeSuite/images
Supported connections:
* PCIEXillybus
* STREAM
* uLimeSDR
