Hello guys,
I have a huge problem, maybe it’s a bug or it’s a faulty board, no way to know exactly because the quick test return success but the signal quality and strength is a total mess, can’t do anything.
Is there a way to wipeout everything from the board in order to reprogram it?
I bought the board from Crowdsupply, who can I contact to request a RMA?
You don’t say which board it is. But in general nothing is programmed to the board, other than its firmware/gateware.
The board would need to be diagnosed as faulty. If you could start by running LimeQuick test and posting the results here. Note that the board must be cold and there must be nothing attached to any of the RF ports during the test.
Thanks. So there is a jumper that can be used to force the FX3 controller to drop into the bootlader, from which point you can use Cypress tools to program firmware. However, this is not advised unless it is confirmed that the firmware is corrupted. And as noted previously, there are no other settings etc. persisted to the board.
If you could please run LimeQuickTest as requested and post the results here.
->Read data: 12 07 1A 12 07 1A 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-13.2 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-14.6 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 → LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-13.5 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-16.1 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-14.7 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-14.0 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
This is actually related to my previous topic (and I already did all the tests you suggested)
And since you have answered to my question in this topic we can proceed there:
I will try to reprogram the board as the last resort.
Many thanks.
