Tried updating driver to Lime driver & got USB FX3. Cannot run LimeUtil --update. Cannot reprogram with LimeUtil.
Ed
Ed
Found my old post about it & got it done.
Ed
Did you try this guide Fixing LimeSDR USB FX3 WestBridge Corruption?
No, that no longer works. I have tried it several times.
Get the Cypress tool (Free online, you just have to sign up. Cytool allows you to flash FX3SDKSetup_1.3.4 to it. Then, do the CMD line LimeUtil --update.
That old tutorial no longer works with newer firmware.
Ed
This is a valuable input since I like to update FX3 as well. So you recommend to do it as described in the USB Board Programming tutorial part 3 and to flash the image via Cypress CyControl tool (Quote: Download the package here). I’ll try this for my case as well. Thank you.
Did you still use the .img file from https://github.com/myriadrf/LimeSDR-USB_FX3/tree/master/Debug? It is from Dec 2017. The SDK version 1.3.4 seems to be from May 2018 instead.
I think I just googled it. Not sure where I found it, but it’s all on a thunbdrive now for safe keeping.
Ed
