COLD STATE
->Start time: Thu Nov 19 14:07:37 2020
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D4C20586F8373, HW=2, GW=1.30
Serial Number: 1D4C20586F8373
Chip temperature: 22 C
->REF clock test
Test results: 42292; 55489; 3150 - PASSED
Results : 6711016 (min); 6711175 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 02 0B 13 02 0B 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-19.2 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-17.0 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 2.74 seconds
AFTER 5 MINUTES WITHOUT ANY INTERACTION IN THE MEANTIME
->Start time: Thu Nov 19 14:22:07 2020
Chip temperature: 52 C
->REF clock test
Test results: 1541; 14738; 27935 - PASSED
Results : 6711087 (min); 6711243 (max) - PASSED
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-20.5 dBFS, 5.00 MHz) - FAILED
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-18.3 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.80 seconds
