Hello everyone!
I want to use LimeSDR-mini like a signal generator.
The output signal wants to output a burst signal like GSM.
The data to be transmitted may be random or anything.
What software can be used to achieve this?
I tried lime suite , but did not achieve…
Thanks!
@tempuranatto - rki,
You’ll find good information here:
Hello everyone.
I bought the lime SDR for the sole purpose of playing around with GSM networks. this has proved to be harder than I thought !
anyhow, I’m following this guide
but on an Ubuntu 16.04 ( with the required changes) and everything is good untill I reach the point of compiling the osmo-trx. so I changed the method of installation and installed it through the apt-get. and it was installed successfully.
but running the command gave me the following error
bahaeddin@ubuntu:~$ osmo…
…and by doing a search on the forum for ‘GSM’ - there is a lot of background out there to find.
Hi martywittrock
Thank you for your comment and good link.
I try the links and search words you gave me.
thanks!
