Is there any sample code or example for Host Application software written in C (preferably) or C++ that can run on Linux.
I am mainly interested in the logic how commands are prepared to be sent to FX3, like CMD_MEMORY_WR to write FW to flash or CMD_SI5351_WR for example.
Thanks for the help. But as you said, I am after an example host application that I can follow, for creating commands to be sent to LimeSDR in Linux.
Can anyone please help. @Zack@andrewback ?
I am able to send control commands to LimeSDR using my own Linux-based host. But can you please help me in sending Events like CY_U3P_USB_EVENT_SETCONF to FX3 FW to start Data transfer.
Also want to confirm whether the complete data flow (e.g. Response to CMD_GET_INFO from NIOS-II) is present in the default code present on git? That means after compiling the FW code and loading it to LimeSDR, if I send CMD_GET_INFO from USB host, I should be getting the values set in NIOS-II code.
