I Can not see my bts in my phone please help ? I configured osmo-bsc and osmo-msc
İt is running that
Where is problem I dont understand ? Help Please ?
root@murat:/etc/osmocom# osmo-trx-lms -C ~/Downloads/osmo-trx-limesdrr.cfg
Info: SSE3 support compiled in and supported by CPU
Info: SSE4.1 support compiled in and supported by CPU
Sat May 18 03:49:16 2019 DLGLOBAL <0004> telnet_interface.c:104 telnet at 127.0.0.1 4237
Sat May 18 03:49:16 2019 DLCTRL <000b> control_if.c:887 CTRL at 127.0.0.1 4236
Sat May 18 03:49:16 2019 DDEV <0002> LMSDevice.cpp:51 [tid=139975464436096] creating LMS device…
Sat May 18 03:49:16 2019 DDEV <0002> LMSDevice.cpp:143 [tid=139975464436096] Opening LMS device…
Sat May 18 03:49:16 2019 DDEV <0002> LMSDevice.cpp:149 [tid=139975464436096] Devices found: 1
Sat May 18 03:49:16 2019 DDEV <0002> LMSDevice.cpp:159 [tid=139975464436096] Device [0]: LimeSDR Mini, media=USB 2.0, module=FT601, addr=24607:1027, serial=1D4C3893CE8AAC
Sat May 18 03:49:16 2019 DDEV <0002> LMSDevice.cpp:168 [tid=139975464436096] Using device[0]
Sat May 18 03:49:17 2019 DDEV <0002> LMSDevice.cpp:194 [tid=139975464436096] Init LMS device
Sat May 18 03:49:17 2019 DDEV <0002> LMSDevice.cpp:101 [tid=139975464436096] Sample Rate: Min=100000 Max=3.072e+07 Step=0
Sat May 18 03:49:17 2019 DDEV <0002> LMSDevice.cpp:230 [tid=139975464436096] Setting sample rate to 1.08333e+06 4
Sat May 18 03:49:17 2019 DDEV <0002> LMSDevice.cpp:236 [tid=139975464436096] Sample Rate: Host=1.08333e+06 RF=3.46667e+07
Sat May 18 03:49:17 2019 DMAIN <0000> osmo-trx.cpp:527 [tid=139975464436096] – Transceiver active with 1 channel(s)
root@murat:/etc/osmocom# osmo-bsc
logging level cc (everything|debug|info|notice|error|fatal)
logging level mgcp (everything|debug|info|notice|error|fatal)
<0010> telnet_interface.c:104 telnet at 127.0.0.1 4242
<0012> input/ipaccess.c:846 enabling ipaccess BSC mode on 0.0.0.0 with OML 3002 and RSL 3003 TCP ports
<0017> control_if.c:887 CTRL at 127.0.0.1 4249
<0007> osmo_bsc_sigtran.c:431 Initializing SCCP connection to MSC msc-0
<0007> osmo_bsc_sigtran.c:441 CS7 Instance identifier, A-Interface: 0
<001d> sccp_user.c:370 msc-0: Creating SS7 instance
<001d> sccp_user.c:397 msc-0: Using SS7 instance 0, pc:0.23.3
<001d> sccp_user.c:411 msc-0: Creating AS instance
<001d> sccp_user.c:421 msc-0: Using AS instance as-clnt-msc-0
<001d> sccp_user.c:426 msc-0: Creating default route
<001d> sccp_user.c:446 msc-0: Creating ASP instance
<001d> sccp_user.c:481 msc-0: Using ASP instance asp-clnt-msc-0
<001d> sccp_user.c:484 msc-0: Creating SCCP instance
<0007> osmo_bsc_sigtran.c:484 (msc-0) A-interface: local (BSC) SCCP address: RI=SSN_PC,PC=0.23.3,SSN=BSSAP
<0007> osmo_bsc_sigtran.c:486 (msc-0) A-interface: remote (MSC) SCCP address: RI=SSN_PC,PC=0.23.1,SSN=BSSAP
<0007> a_reset.c:106 A-RESET(msc-0)[0x55d06a0328e0]{DISC}: (re)sending BSSMAP RESET message…
<0007> osmo_bsc_sigtran.c:92 Sending RESET to MSC: RI=SSN_PC,PC=0.23.1,SSN=BSSAP
<001c> m3ua.c:507 XUA_AS(as-clnt-msc-0)[0x55d06a031b40]{AS_DOWN}: Event AS-TRANSFER.req not permitted
^Csignal 2 received
<0004> bsc_init.c:48 shutting down OML for BTS 0
root@murat:/etc/osmocom# osmo-msc
<0011> telnet_interface.c:104 telnet at 127.0.0.1 4254
<000c> smpp_smsc.c:1011 SMPP at 0.0.0.0 2775
<0018> control_if.c:887 CTRL at 127.0.0.1 4255
<001b> gsup_client.c:74 GSUP connecting to 127.0.0.1:4222
<0006> msc_main.c:373 CS7 Instance identifiers: A = Iu = 0
<001e> sccp_user.c:370 OsmoMSC-A-Iu: Creating SS7 instance
<001e> sccp_user.c:397 OsmoMSC-A-Iu: Using SS7 instance 0, pc:0.23.1
<001e> sccp_user.c:411 OsmoMSC-A-Iu: Creating AS instance
<001e> sccp_user.c:421 OsmoMSC-A-Iu: Using AS instance as-clnt-OsmoMSC-A-Iu
<001e> sccp_user.c:426 OsmoMSC-A-Iu: Creating default route
<001e> sccp_user.c:446 OsmoMSC-A-Iu: Creating ASP instance
<001e> sccp_user.c:481 OsmoMSC-A-Iu: Using ASP instance asp-clnt-OsmoMSC-A-Iu
<001e> sccp_user.c:484 OsmoMSC-A-Iu: Creating SCCP instance
<0010> a_iface.c:641 Initializing SCCP connection to stp…
