Hello everyone,
I have followed steps at https://myriadrf.org/blog/installing-the-novena-rf-driver-and-gnu-radio/ and managed to compile SoapySDR and the host and kernel packages from the Novena-RF repo (since I’m running a 4.4 kernel). When I issue:
SoapySDRUtil --make="driver=novena"
then I get the same output as in the blog post (the post shows one dash instead of two btw). But when I issue:
/usr/lib/uhd/examples/rx_ascii_art_dft --rate=1e6 --freq=1.8e9 --gain=30 --ref-lvl=-60
(again, two dashes for the --ref-lvl part) then I get the following error:
linux; GNU C++ version 4.9.1; Boost_105500; UHD_003.007.003-0-unknown
UHD Warning:
Unable to set the thread priority. Performance may be negatively affected.
Please see the general application notes in the manual for instructions.
EnvironmentError: OSError: error in pthread_setschedparam
Creating the usrp device with: ...
Error: LookupError: KeyError: No devices found for ----->
Empty Device Address
On the kosagi forums there are a couple of suggestions like creating a symbolic link and such, but none of the solutions worked for me. So SoapySDRUtil sees my Novena-RF but UHD doesn’t.
I also tried building gr-osmosdr from source, but cmake gives me an error that the version of gnuradio that I have is too old, even though I’m using the same version of gnuradio and uhd as in the blog post. Anyone else facing the same issues?
