Perhaps someone can help.
I have below simple python script that works fine so far, but I always have to plug/unplug the Lime Mini to make it run properly, otherwise, the filter doesn’t set (GFIR LPF cannot be set to the requested bandwith…)
Any suggestion?
#!/usr/bin/env python3
-- coding: utf-8 --
from gnuradio import analog
from gnuradio import filter
from gnuradio.filter import firdes
from gnuradio import gr
import sys
from gnuradio.eng_arg import eng_float, intx
import limesdr
import time
class noise_source(gr.top_block):
def __init__(self):
gr.top_block.__init__(self, "")
# Variables
self.sample_rate = sample_rate = 32000
self.gain = gain = 10
# Blocks
#self.LimeSDR.calibrate(2.5e6, 0)
self.Noise_Source = analog.noise_source_f(analog.GR_UNIFORM, 1, 0)
self.LimeSDR = limesdr.sink('', 0, '', '')
self.LimeSDR.set_sample_rate(sample_rate)
self.LimeSDR.set_center_freq(500e6, 0)
self.LimeSDR.set_bandwidth(5e6, 0)
self.LimeSDR.set_digital_filter(sample_rate, 0)
self.LimeSDR.set_gain(gain, 0)
self.LimeSDR.set_antenna(255, 0)
self.band_pass_filter_1 = filter.fir_filter_fcc(1,firdes.complex_band_pass(1,sample_rate,300,3500,50,firdes.WIN_HAMMING,6.76))
# Connections
self.connect((self.Noise_Source, 0), (self.band_pass_filter_1, 0))
self.connect((self.band_pass_filter_1, 0), (self.LimeSDR, 0))
def set_sample_rate(self, sample_rate):
self.band_pass_filter_1.set_taps(firdes.complex_band_pass(1, self.sample_rate, 200, 3500, 50, firdes.WIN_HAMMING, 6.76))
def set_gain(self, gain):
self.gain = gain
self.LimeSDR.set_gain(self.gain, 0)
def main(gnu_block=noise_source):
gb = gnu_block()
gb.start()
for gain in range(10,73,2):
print (gain)
gb.set_gain(gain)
time.sleep(1)
gb.stop()
sys.exit()
if name == ‘main’:
main()
