Greetings,
After using the gr-limesdr C++ API for a while, I noticed some things which could be improved a little, and hopefully other users of the C++ API might find these suggestions useful.
The stream analyzer is controlled by a variable which is only set at compile time. To enable it, one needs to change the code and recompile gr-limesdr. It is suggested this could be made an option for sink / source object initialization, for easier stream debugging.
Time tags are sent by the source at the start of the stream, and after any reconfiguration, as well as when dropped packets are detected. It is suggested to create a configurable option to enable sending RX_TIME tags for each sample packet received. This allows for easier time keeping, without having to count potentially billions of samples with the resulting integer precision / overflow problems. Also, there seems to be a bug in GNU radio 3.8 where the time tag at offset zero in the stream is not propagated, this works around it.
The device initialization and release code is peppered with exit(0) calls. It is suggested to replace these calls with throwing runtime exceptions, as other GNU radio sink / source packages use ( eg. throw std::runtime_error). This allows for more graceful handling of device initialization errors downstream from these blocks.
Let me know what are your opinions regarding these proposals.
