we are using the LimeSDR USB with a modified gateware. Currently we are on gateware version 2.16 from the master branch and using Quartus environment with the schematic “lms7_trx_top.bdf” as top-level. For the reason that there are many improvements in the gateware during the last months, our plan was to update to the latest version 2.19. But unfortunately the top-level schematic of this version is not up to date and it is not possible to build. With HDL on top it is not a problem and the build process works fine. But we are coming from analog design and it is easier for us to have a schematic on top. For this my question or request, if it possible to update the file “lms7_trx_top.bdf” in the LimeSDR-USB_GW repository (https://github.com/myriadrf/LimeSDR-USB_GW) so that it match to the HDL code.
Thank you very much
sdr_frickler
