I am intending to use Lime Micro Device LMS7002M in frequency hopping mode for both Tx and Rx paths over a bandwidth of 10Mhz. Wanted to know the precise procedure using which we should modify the synthesizer values for the same? Will help if anyone who has worked this out can share some C-code/pseudocode for the same.
Maybe you should try to power down the LO buffer from SXT to SXR in SXT/SXR tab
