I have the following firmware problem with my LimeSDR.
- I did try to upgrade the firmware up to 1.4 using LimeSuiteGUI (linux) but the operation failed (read failed on local disk image)
- Then my LimeSDR appeared as a “Cybpress WestBridge” device
- So I did use the Cypress USB Control Center to reflash the “LimeSDR-USB_fx3_fw” firmware
- Then my LimeSDR appeared again as a “LimeSDR Usb” device
- Then I did try again to upgrade to 1.4 and the operation did complete successfully
But… the device now appears again as a “Cybpress WestBridge” device.
I did try several times, and the very same thing happens.
[100%] 579832/579832 Bytes programming: completed (/usr/share/LimeSuite/images/19.01/LimeSDR-USB_HW_1.4_r2.20.rbf)2.20.rbf)
Programming update complete!
> lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 04b4:00f3 Cypress Semiconductor Corp.
Bus 001 Device 002: ID 80ee:0021 VirtualBox USB Tablet
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
