KarlL
1
Hi all,
When accessing the GPIO through SoapySDR, it seems to be taking around 250µs for a call like writeGPIODir or writeGPIO.
Is this normal and should a different approach be used if one wants to react faster?
Is anyone using the GPIO at faster speeds somehow?
You could try using Lime Suite directly.
KarlL
3
Thanks Andrew for the advice. I’m not seeing much difference though. At least it means there’s no noticeable overhead when using the SoapySDR API.
I guess I’ll try to use some Arduino or Raspberry Pi to control the GPIO, to see if I can drive it faster.
So this thread is about transferring samples, but I wonder if there is anything in here which might point to a potential solution:
E.g. some protocol buffering that could be shrunk to reduce latency.
KarlL
5
That’s interesting thanks, maybe not directly related to the GPIO but it might be useful indeed to bring down latency when receiving samples.
