I’m a new limesdr player,while yesterday i trying to use OpenBTS with my LimeSDR , i met some problems can’t be overcome,anyone could help me?Thanks a million!
Details as Follows:
gogogo@ubuntu:~/sdr/dev/openbts/Transceiver52M$ sudo ./transceiver
[sudo] password for gogogo:
linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_003.010.002.000-3-g122bfae1
Using internal frequency reference
Using OpenUSRP
Gateware version mismatch!
Expected gateware version 2, revision 9
But found version 2, revision 8
Reference clock 30.720 MHz
LMS7002M cache /home/father/.limesuite/LMS7002M_cache_values.db
Rx Filter calibrated from cache
Tx Filter calibrated from cache
– Setting master clock rate selection to ‘manual’.
ALERT 30914:30969 2017-09-06T16:19:18.5 UHDDevice.cpp:709:check_rx_md_eremphasized textr: UHD: Receive timed out
ALERT 30914:30969 2017-09-06T16:19:18.5 UHDDevice.cpp:783:readSamples: UHD: Version 003.010.002.000-3-g122bfae1
ALERT 30914:30969 2017-09-06T16:19:18.5 UHDDevice.cpp:784:readSamples: UHD: Unrecoverable error, exiting…
