I’m trying to generate a GFSK signal at 450Mhz using gnuradio-3.7.13-4-4build1 (Ubuntu 19.10 amd64) and a LimeSDR-mini.
If I set oversample=1, then I get the following errors. However, leaving oversample at “Default”, it works. So I have a work around, but the bug might be useful to someone.
LimeSuite and gr-limesdr were built from source (stable and master branches respectively).
Here is the gnuradio-companion log:
LimeSuite Sink (TX) info
Connecting to device
LimeSuite version: 19.04.0-gabf82140
gr-limesdr version: 2.1.4
Device list:
Nr.:0 device:LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D53BA19C07646
INFO: device_handler::open_device(): no serial number. Using first device in the list.
Use “LimeUtil --find” in terminal to find prefered device serial.
Reference clock 40.00 MHz
Using device: LimeSDR-Mini(1D53BA19C07646) GW: 1.28 FW: 6
INFO: device_handler::set_samp_rate(): set sampling rate: 0.072 MS/s.
INFO: device_handler::set_oversampling(): SetFrequencyCGEN(0.288 MHz) - cannot deliver requested frequency
Followed by a Python crash and libusb errors…
