made a video comparing the limesdr mini and an rtlsdr E4000
https://www.youtube.com/watch?v=eAO0OIhhUBg
i believe the lime mini is more sensitive.
you guys let me know what you think
i needed a pretty tight signal (narrow) and stable so i was taking measurements of a ATSC Pilot signal about 55 miles away.
you can notice doppler frequency shift
i dont know to much about this process yet but it is very interesting and nice to know the lime mini does it better then a regular rtlsdr device.
thank goodness as it costs more
Sounds a little… cryptic?
didnt want to put up false information so i had to delete and remake
Ah, OK, thanks
i also added another video (be sure to watch towards the end as i adjust a couple settings
mainly i matched both dongles bandwidth to 1khz
when i started video i thought both were set to 1khz viewable spectrum but the lime mini was 2khz
https://www.youtube.com/watch?v=ndRelKgVw2A
yea i been doing multiple tests
i have 4 dongles
- lime-mini
- E4000 rtlsdr
- R820T2 rtlsr’s
all the rtlsdr’s when zoomed way in with 1hz Resolution Bandwidh in GQRX FFT settings
only the lime-mini has the wiggle
can someone tell me how to fix the wiggle?
