When I terminate an FG with ^C (which I do for command-line apps), the next attempt to start
the device yields:
[ERROR] Read(64 bytes) failed
Expected gateware version 2, revision 15
[INFO] Reference: 3.072e+07 MHz
[ERROR] SetFrequencySXT(1250 MHz) - cannot deliver frequency
[ERROR] SetFrequencyCGEN(80 MHz) failed
[ERROR] SetFrequencyCGEN(448 MHz) failed
[ERROR] SetFrequencySXR(1420.41 MHz) - cannot deliver frequency
[INFO] RX LPF configured
^C[INFO] Rx calibration finished
[ERROR] SetFrequencySXR(450 MHz) - cannot deliver frequency
[WARNING] Channel alignment failed
[ERROR] SetFrequencySXT(450.24 MHz) - cannot deliver frequency
But on a start subsequent to that, it works fine. My suspicion is old data in the USB buffers that aren’t being cleared out on a subsequent run before doing the start-up “dance” with the device.
