bassically i get a signal produced at ±100 mhz up and down the spectrum and in some cases near 700 mhz and 800mhz its allot stronger and is very noisey.
this is all tested without running any grc scripts or transmitiing anything. these are purely done with the limesdr-mini plugged into usb.
some things ive tested.
i have fully shielded the device with no real change.
i have reinstalled firmware.
i have run on usb 2.0.
i have run and tested with different usb cables.
i have run through all tests using the limesuite and suchlike with no problems.
i noticed at 700mhz and some other frequencies i am able to tap the fpga pin area with my finger and the device transmits large pulses and create noise over the spectrum. even if i put my finger near by the pins.
"the fpga pins at the top next to the jtag pins " https://wiki.myriadrf.org/LimeSDR-Mini_v1.1_hardware_description
