just got done doing alot of tests and tried to start gqrx and i have no lights on board at all
i dont get any lights on the limesdr-mini
this is what SoapySDRUtil --info, --find and --probe
en1gma@en1gma–lap:~$ SoapySDRUtil --info
Lib Version: v0.6.1-2
API Version: v0.6.0
ABI Version: v0.6
Install root: /usr
Search path: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6
Search path: /usr/local/lib/x86_64-linux-gnu/SoapySDR/modules0.6
Search path: /usr/local/lib/SoapySDR/modules0.6
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6/libHackRFSupport.so
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6/libLMS7Support.so
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6/libRedPitaya.so
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6/libairspySupport.so
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6/libaudioSupport.so
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6/libbladeRFSupport.so
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6/libmiriSupport.so
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6/libosmosdrSupport.so
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6/libremoteSupport.so
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6/librfspaceSupport.so
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6/librtlsdrSupport.so
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6/libuhdSupport.so
Loading modules… linux; GNU C++ version 7.3.0; Boost_106501; UHD_003.010.003.000-0-unknown
done
Available factories…airspy, audio, bladerf, hackrf, lime, miri, null, osmosdr, redpitaya, remote, rfspace, rtlsdr, uhd,
en1gma@en1gma–lap:~$ SoapySDRUtil --find
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Found device 0
default_input = True
default_output = True
device_id = 0
driver = audio
label = hw:HDA Intel PCH,0
Found device 1
default_input = False
default_output = False
device_id = 1
driver = audio
label = default
Found device 2
addr = 24607:1027
driver = lime
label = LimeSDR Mini [USB 3.0] 1D3BD0C4F0CDFF
media = USB 3.0
module = FT601
name = LimeSDR Mini
serial = 1D3BD0C4F0CDFF
en1gma@en1gma–lap:~$ SoapySDRUtil --probe
Probe device
– Device identification
driver=Audio
hardware=Audio
device_id=0
origin=https://github.com/pothosware/SoapyAudio
– Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
- Stereo Sample Offset - Offset stereo samples for off-by-one audio inputs.
[key=sample_offset, default=0, type=string, options=(-2, -1, 0, 1, 2)] - Rig Control - Select hamlib rig control type.
[key=rig, type=string, options=(2901, 2516, 2517, 2513, 2518, 508, 506, 505, 504, 514, 503, 515, 502, 501, 513, 516, 1701, 2506, 2503, 2303, 2304, 902, 903, 221, 229, 238, 2501, 2507, 2512, 2301, 236, 2515, 1, 2, 354, 302, 303, 372, 304, 306, 307, 360, 355, 309, 310, 311, 312, 370, 313, 361, 314, 315, 316, 373, 319, 320, 321, 322, 367, 323, 346, 324, 326, 327, 347, 357, 363, 328, 329, 362, 330, 345, 356, 331, 332, 334, 344, 368, 365, 335, 3001, 3003, 3002, 402, 401, 403, 404, 336, 358, 340, 337, 341, 338, 339, 343, 366, 369, 342, 371, 605, 606, 607, 2511, 1801, 215, 233, 217, 219, 220, 223, 226, 234, 227, 230, 225, 214, 202, 203, 228, 201, 204, 216, 231, 237, 224, 205, 206, 207, 208, 209, 210, 222, 211, 213, 239, 1004, 374, 2514, 353, 352, 2801, 2401, 1105, 1103, 804, 2702, 2701, 2502, 232, 1404, 1402, 2509, 2201, 364, 351, 1603, 1612, 1604, 1605, 1607, 1602, 1601, 1608, 1609, 1611, 1613, 802, 806, 801, 803, 812, 810, 811, 133, 2601, 2602, 1204, 1501, 1502, 1503, 1504, 1505, 1506, 1507, 1509, 117, 119, 118, 121, 103, 124, 134, 129, 127, 110, 105, 106, 107, 109, 120, 111, 101, 122, 115, 123, 113, 114, 128, 131, 116, 135, 132, 130, 104, 125, 126, 2508)] - Rig Serial Rate - Select hamlib rig serial control rate.
[key=rig_rate, default=57600, type=string, options=(1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 128000, 256000)] - Rig Serial Port - hamlib rig Serial Port dev / COMx / IP-Address
[key=rig_port, default=/dev/ttyUSB0, type=string]
– RX Channel 0
Full-duplex: YES
Supports AGC: YES
Stream formats: CS8, CS16, CF32
Native format: CS16 [full-scale=65536]
Stream args:
- Channel Setup - Input channel configuration.
[key=chan, default=mono_l, type=string, options=(mono_l, mono_r, stereo_iq, stereo_qi)]
Antennas: RX
Full gain range: [0, 0] dB
Full freq range: [0, 6000] MHz
RF freq range: [0, 6000] MHz
Sample rates: 0.0441, 0.048, 0.096, 0.192 MSps
‘gqrx -r’ with selecting limesdr-mini and i set device string to “soapy=0,driver=0”
en1gma@en1gma–lap:~$ gqrx -r
Controlport disabled
No user supplied config file. Using “default.conf”
“/home/en1gma/.config/gqrx/default.conf” deleted
gr-osmosdr v0.1.x-xxx-xunknown (0.1.5git) gnuradio 3.7.11
built-in source types: file osmosdr fcd rtl rtl_tcp uhd plutosdr miri hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp
FM demod gain: 3.05577
Resampling audio 96000 -> 48000
IQ DCR alpha: 1.04166e-05
Using audio backend: auto
BookmarksFile is /home/en1gma/.config/gqrx/bookmarks.csv
RtApiAlsa::getDeviceInfo: snd_pcm_open error for device (hw:0,0), Device or resource busy.
getDeviceList : Available input devices:
“Ettus SOAPY”
“Ettus SOAPY”
“Ettus SOAPY (LimeSDR Mini) 1D3BD0C4F0CDFF”
“PlutoSDR”
“RFSPACE SDR-IQ Receiver”
“RFSPACE SDR-IP Receiver”
“RFSPACE NetSDR Receiver”
“RFSPACE Cloud-IQ Receiver”
“hw:HDA Intel PCH,0”
“default”
“LimeSDR Mini [USB 3.0] 1D3BD0C4F0CDFF”
“RTL-SDR Spectrum Server”
“Red Pitaya Transceiver Server”
“Complex Sampled (IQ) File”
Loading configuration from: “default.conf”
Configuration file: “/home/en1gma/.config/gqrx/default.conf”
No change in output device:
old:
new:
New FFT rate: 25 Hz
Requested bandwidth: 0 Hz
Actual bandwidth : 0 Hz
setFreqCorr : 0 ppm
New LNB LO: 0 Hz
updateHWFrequencyRange failed fetching new hardware frequency range
New mode index: 2
Filter preset for mode 2 LO: -5000 HI: 5000
Generating taps for new filter LO:-5000 HI:5000 TW:2000 Taps: 115
setFftRate to “25 fps”
New FFT rate: 25 Hz
New FFT rate: 25 Hz
setFftSize to “8192”
New FFT rate: 25 Hz
Launching I/O device editor
firstTimeConfig
CIoConfig : Available output devices:
0 : “Built-in Audio Analog Stereo”
New input device selected: 3
Label: “LimeSDR Mini [USB 3.0] 1D3BD0C4F0CDFF”
Devstr: “addr=24607:1027,driver=lime,media=‘USB 3.0’,module=FT601,name=‘LimeSDR Mini’,serial=1D3BD0C4F0CDFF,soapy=2”
saveConfig
Loading configuration from: “/home/en1gma/.config/gqrx/default.conf”
[INFO] Make connection: ‘LimeSDR Mini [USB 3.0] 1D3BD0C4F0CDFF’
[ERROR] Read(64 bytes) failed
[ERROR] Write(64 bytes) failed
[INFO] Device name: UNKNOWN
[INFO] Reference: -1e-06 MHz
just repeats this over and over. all while limesdr has no power light
tested it on my rpi3 and it also has no power light when connected to it
tested with LimeSuiteGUI too
when i try to connect it says this
21:12:42] INFO: Disconnected control port
[21:12:49] ERROR: Read(64 bytes) failed
[21:12:49] ERROR: Write(64 bytes) failed
[21:12:53] ERROR: Write(64 bytes) failed
[21:12:53] INFO: Connected Control port: UNKNOWN FW:0 HW:0 Protocol:0 GW:0.0 Ref Clk: -0.00 MHz
en1gma@en1gma–lap:~$ LimeQuickTest
->Start time: Mon Oct 22 21:21:03 2018
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D3BD0C4F0CDFF
Serial Number: 1D3BD0C4F0CDFF
Failed to connect
please help
