Hi All,
Anyone has idea about the certification of the CS-lime-01 . We require FCC and UL certification for this.
Regards,
Rohit Soni
Amantya technologies
Hi All,
Regards,
Rohit Soni
I had to lookup what a CS-lime-01 was, and it is more commonly known as a LimeSDR-USB.
For FCC certification, my basic understanding is that would be up to you, if you were planning on integrating any generic SDR board into a commercial product and increasing the TX power above laboratory test equipment level of ~10dBm. You would also need to add external filtering on the output and limit the frequency tuning range to the appropriate bands only.
Thankyou @mzs. We have developed the NBIOT test tool with very limited power. Either 0 or 4 dBm. Do we still need to put filters at output side? Any particular suggestion for that? Also would this board UL comply? i noticed 94V-0 is printed on the board so can we get a certificate regarding this?
