I put my lime mini to my bag (although I though it was secure) and now the LimeQuickTest fails with the following error
$ LimeQuickTest
->Start time: Thu Aug 27 01:13:12 2020
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D588F01B6A2F2, HW=3, GW=1.30
Serial Number: 1D588F01B6A2F2
Chip temperature: 27 C
->REF clock test
Test results: 65406; 13067; 26264 - PASSED
Results : 6711019 (min); 6711019 (max) - FAILED
FAILED
->Clock Network Test FAILED
->Read data: 13 0A 16 13 0A 16 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-12.4 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-13.3 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests FAILED <=
Elapsed time: 2.43 seconds
Not sure why ->VCTCXO consistently fails. Is there something I can check on the board? I don’t see any physical damage.
damn.
