we are performing some tests with the new limesuiteNG development branch on a LimeSDR XTRX.
To this end, we execute the dualRXTX example which shows some output on our signal analyzer at 1.5GHz.
However, if we change the frequencyLO variable to some other value in the allowed range (say 3.5GHz or 2.5GHz), then the output is not given.
We also noticed, that enabling the calibration on RX and TX does fail, but we could not figure out why this is the case. The error code that we retrieve upon debugging is: Rx ch%i DC/IQ calibration failed: %s leading to a segmentation fault in the example.
Is this an error in limesuiteNG or is additional configuration required to perform successful calibration?
Thanks for your help!
We attach the logs for 1.5GHz and 3.5GHz below:
1.5 GHz:
sens@nuc4:~/Downloads/LimeSuiteNG/vbuild ./bin/examples/dualRXTX
Devices found :
0: LimeXTRX0, media=PCIe, addr=/dev/LimeXTRX0_control, serial=0000000000000000
Configuring device ...
SetFrequencySXT, (1500.000 MHz)INT 111, FRAC 403298, DIV_LOCH 1, EN_DIV2_DIVPROG 1
Expected VCO 6000.00 MHz, RefClk 26.00 MHz
Tuning VCOL :
TuneVCO(SXT) ICT_VCO: 192
TuneVCO(SXT) - attempted VCO too low
VCOL : failed to lock
Tuning VCOM :
TuneVCO(SXT) - searching interval [0:128]
binary search:
csw=64 cmphl=0
csw=96 cmphl=0
csw=112 cmphl=0
csw=120 cmphl=0
csw=124 cmphl=0
csw=126 cmphl=0
csw=127 cmphl=0
adjust with linear search:
CSW interval failed to lock
TuneVCO(SXT) - searching interval [128:256]
binary search:
csw=192 cmphl=3
csw=160 cmphl=0
csw=176 cmphl=3
csw=168 cmphl=2
csw=172 cmphl=2
csw=174 cmphl=2
csw=175 cmphl=2
csw=167 cmphl=0
CSW: lowest=168, highest=175, will use=171
choosing wider CSW locking range: low=168, high=175
TuneVCO(SXT) - confirmed lock with final csw=171, cmphl=2
VCOM : csw=171 tune ok
Tuning VCOH :
TuneVCO(SXT) - attempted VCO too high
VCOH : failed to lock
Selected: VCOM, CSW_VCO: 171
Sampling rate set(10.000 MHz): CGEN:80.000 MHz, Decim: 2^1, Interp: 2^1
INT 91, FRAC 322638, DIV_OUTCH_CGEN 14
VCO 2400.00 MHz, RefClk 26.00 MHz
ICT_VCO_CGEN: 16
csw 172; interval [169, 175]
FPGA::SetInterfaceFreq tx:20.000 MHz rx:20.000 MHz channel:0
FPGA SetPllFrequency: PLL[1] input:20.000 MHz clockCount:2
CLK[0] Fout:20.000 MHz bypass:0 phase:114.26 findPhase: 0
CLK[1] Fout:20.000 MHz bypass:0 phase:114.26 findPhase: 1
FPGA PLL[1] M=64, N=1, Fvco=1280.000 MHz (Requested 1280.000 MHz)
FPGA PLL[1] PLLCFG_START
FPGA PLL[1] PLLCFG_START done
PLL Clock[0] PHCFG_START
PLL Clock[0] PHCFG_START done
PLL Clock[1] PHCFG_START
PLL Clock[1] PHCFG_START done
FPGA SetPllFrequency: PLL[0] input:20.000 MHz clockCount:2
CLK[0] Fout:20.000 MHz bypass:0 phase:95.03 findPhase: 0
CLK[1] Fout:20.000 MHz bypass:0 phase:95.03 findPhase: 1
FPGA PLL[0] M=64, N=1, Fvco=1280.000 MHz (Requested 1280.000 MHz)
FPGA PLL[0] PLLCFG_START
FPGA PLL[0] PLLCFG_START done
PLL Clock[1] PHCFG_START error, reg:0x0021=0x000D, errorBits:0x0008
SDR configured in 843ms
StopStreaming
/dev/LimeXTRX0_trx0 usePoll:1 rxSamplesInPkt:256 rxPacketsInBatch:3, DMA_ReadSize:6192, batchSizeInTime:0us
Stream0 samplesInTxPkt:256 maxTxPktInBatch:3, batchSizeInTime:infus
StopStreaming
ResetTimestamp
SetOSThreadPriority: Failed to set priority(6), schec_prio(1), policy(1), ret(99)
StartStreaming
Stream started ...
/dev/LimeXTRX0_trx0 Rx: 80.620 MB/s | TS:9996288 pkt:39048 o:0(+0) l:0(+0) dma:13016/13020(4) swFIFO:0
Total samples received: 9997312 signal amplitude: 0.325509 total samples sent: 9997312
/dev/LimeXTRX0_trx0 Tx: 77.679 MB/s | TS:10061824 pkt:37866 o:0 shw:12622/12548(+74) u:396(+396) l:18(+18) tsAdvance:-74240/+60247/+64768, f:0
/dev/LimeXTRX0_trx0 Rx: 80.645 MB/s | TS:19998720 pkt:78120 o:0(+0) l:0(+0) dma:26040/26044(4) swFIFO:0
Total samples received: 19999744 signal amplitude: 0.283218 total samples sent: 19999744
/dev/LimeXTRX0_trx0 Tx: 80.645 MB/s | TS:20064256 pkt:76938 o:0 shw:25646/25573(+73) u:396(+0) l:18(+0) tsAdvance:+54784/+62758/+64768, f:0
/dev/LimeXTRX0_trx0 Rx: 80.620 MB/s | TS:29998080 pkt:117180 o:0(+0) l:0(+0) dma:39060/39064(4) swFIFO:1
Total samples received: 29997056 signal amplitude: 0.283389 total samples sent: 29997056
/dev/LimeXTRX0_trx0 Tx: 80.632 MB/s | TS:30061312 pkt:115989 o:0 shw:38663/38595(+68) u:396(+0) l:18(+0) tsAdvance:+52480/+62627/+64768, f:0
/dev/LimeXTRX0_trx0 Rx: 80.645 MB/s | TS:40000512 pkt:156252 o:0(+0) l:0(+0) dma:52084/52088(4) swFIFO:0
Total samples received: 40001536 signal amplitude: 0.28423 total samples sent: 40001536
/dev/LimeXTRX0_trx0 Tx: 80.645 MB/s | TS:40066816 pkt:155073 o:0 shw:51691/51616(+75) u:396(+0) l:18(+0) tsAdvance:+54784/+62693/+64768, f:0
/dev/LimeXTRX0_trx0 Rx: 80.620 MB/s | TS:50002176 pkt:195321 o:0(+0) l:0(+0) dma:65107/65108(1) swFIFO:1
Total samples received: 50002944 signal amplitude: 0.28424 total samples sent: 50002944
/dev/LimeXTRX0_trx0 Tx: 80.632 MB/s | TS:50068480 pkt:194142 o:0 shw:64714/64639(+75) u:396(+0) l:18(+0) tsAdvance:+42496/+62567/+64768, f:0
/dev/LimeXTRX0_trx0 Rx: 80.669 MB/s | TS:60002304 pkt:234384 o:0(+0) l:0(+0) dma:12592/12600(8) swFIFO:0
/dev/LimeXTRX0_trx0 Tx: 80.620 MB/s | TS:60067072 pkt:233199 o:0 shw:12197/12126(+71) u:396(+0) l:18(+0) tsAdvance:+54784/+62698/+64768, f:0
Total samples received: 60003328 signal amplitude: 0.284678 total samples sent: 60003328
/dev/LimeXTRX0_trx0 Rx: 80.620 MB/s | TS:70007808 pkt:273468 o:0(+0) l:0(+0) dma:25620/25620(0) swFIFO:5
/dev/LimeXTRX0_trx0 Tx: 80.657 MB/s | TS:70067968 pkt:272265 o:0 shw:25219/25147(+72) u:396(+0) l:18(+0) tsAdvance:+54016/+62719/+64768, f:0
Total samples received: 70007808 signal amplitude: 0.28273 total samples sent: 70007808
/dev/LimeXTRX0_trx0 Tx: 80.620 MB/s | TS:80070400 pkt:311337 o:0 shw:38243/38168(+75) u:396(+0) l:18(+0) tsAdvance:+54784/+62784/+64768, f:0
/dev/LimeXTRX0_trx0 Rx: 80.645 MB/s | TS:80007168 pkt:312528 o:0(+0) l:0(+0) dma:38640/38644(4) swFIFO:0
Total samples received: 80008192 signal amplitude: 0.28419 total samples sent: 80008192
/dev/LimeXTRX0_trx0 Rx: 80.620 MB/s | TS:90008064 pkt:351594 o:0(+0) l:0(+0) dma:51662/51664(2) swFIFO:1
Total samples received: 90007552 signal amplitude: 0.28566 total samples sent: 90007552
/dev/LimeXTRX0_trx0 Tx: 80.632 MB/s | TS:90072064 pkt:350406 o:0 shw:51266/51192(+74) u:396(+0) l:18(+0) tsAdvance:+53248/+62713/+64768, f:0
Rx0: packetsIn: 390615
/dev/LimeXTRX0_trx0 Tx: 73.357 MB/s | TS:100061440 pkt:389427 o:0 shw:64273/64273(+0) u:396(+0) l:18(+0) tsAdvance:+51712/+62663/+64768, f:0
StopStreaming
Tx Loop totals: packets sent: 389427 (0x0005F133) , FPGA packet counter: 389427 (0x0005F133), diff: 0, FPGA tx drops: 32
DeviceRegistry Removed: LitePCIe
DeviceRegistry Removed: FTDI
DeviceRegistry Removed: FX3
(For this one we notice that there is a DC bias, which does not always occur (i.e., power cycling solves this issue until it reoccurs).)
3.5 GHz:
sens@nuc4:~/Downloads/LimeSuiteNG/vbuild$ ./bin/examples/dualRXTX
Devices found :
SetFrequencySXT, (3500.000 MHz)INT 130, FRAC 645277, DIV_LOCH 0, EN_DIV2_DIVPROG 1
Expected VCO 7000.00 MHz, RefClk 26.00 MHz
Tuning VCOL :
Tuning VCOM :
VCOM : failed to lock
Tuning VCOH :
binary search:
csw=64 cmphl=0
csw=96 cmphl=0
csw=112 cmphl=0
csw=120 cmphl=2
csw=124 cmphl=2
csw=126 cmphl=2
csw=127 cmphl=2
csw=119 cmphl=2
csw=118 cmphl=0
CSW: lowest=119, highest=127, will use=123
binary search:
csw=192 cmphl=3
csw=160 cmphl=3
csw=144 cmphl=3
csw=136 cmphl=2
csw=140 cmphl=2
csw=142 cmphl=2
csw=143 cmphl=2
csw=135 cmphl=2
csw=134 cmphl=2
csw=133 cmphl=2
csw=132 cmphl=2
csw=131 cmphl=2
csw=130 cmphl=2
csw=129 cmphl=2
csw=128 cmphl=2
CSW: lowest=128, highest=143, will use=135
CSW is locking in one continous range: low=119, high=143
TuneVCO(SXT) - confirmed lock with final csw=131, cmphl=2
VCOH : csw=131 tune ok
Selected: VCOH, CSW_VCO: 131
ICT_VCO_CGEN: 16
SDR configured in 853ms
StopStreaming
StopStreaming
ResetTimestamp
StartStreaming
Stream started ...
/dev/LimeXTRX0_trx0 Rx: 80.620 MB/s | TS:9998592 pkt:39057 o:0(+0) l:0(+0) dma:13019/13020(1) swFIFO:11/dev/LimeXTRX0_trx0 Tx: 80.124 MB/s | TS:10053376 pkt:39018 o:0 shw:13006/12941(+65) u:0(+0) l:0(+0) tsAdvance:+36352/+60618/+64768, f:0
Total samples received: 9990144 signal amplitude: 0.373463 total samples sent: 9990144
/dev/LimeXTRX0_trx0 Rx: 80.620 MB/s | TS:19997952 pkt:78117 o:0(+0) l:0(+0) dma:26039/26040(1) swFIFO:3
/dev/LimeXTRX0_trx0 Tx: 80.626 MB/s | TS:20059648 pkt:78105 o:0 shw:26035/25962(+73) u:0(+0) l:0(+0) tsAdvance:+32512/+59868/+64768, f:1
Total samples received: 19996672 signal amplitude: 0.165747 total samples sent: 19996672
/dev/LimeXTRX0_trx0 Tx: 80.632 MB/s | TS:30059008 pkt:117165 o:0 shw:39055/38984(+71) u:0(+0) l:0(+0) tsAdvance:+48640/+60839/+64768, f:1
Total samples received: 29996032 signal amplitude: 0.165367 total samples sent: 29996032
/dev/LimeXTRX0_trx0 Rx: 80.645 MB/s | TS:29998080 pkt:117180 o:0(+0) l:0(+0) dma:39060/39064(4) swFIFO:2
/dev/LimeXTRX0_trx0 Tx: 80.626 MB/s | TS:40059904 pkt:156231 o:0 shw:52077/52005(+72) u:0(+0) l:0(+0) tsAdvance:+30208/+59809/+64768, f:0
Total samples received: 39996416 signal amplitude: 0.172751 total samples sent: 39996416
/dev/LimeXTRX0_trx0 Rx: 80.620 MB/s | TS:39999744 pkt:156249 o:0(+0) l:0(+0) dma:52083/52084(1) swFIFO:3
/dev/LimeXTRX0_trx0 Rx: 80.620 MB/s | TS:49997568 pkt:195303 o:0(+0) l:0(+0) dma:65101/65104(3) swFIFO:0
Total samples received: 49997824 signal amplitude: 0.163238 total samples sent: 49997824
/dev/LimeXTRX0_trx0 Tx: 80.626 MB/s | TS:50062336 pkt:195303 o:0 shw:65101/65029(+72) u:0(+0) l:0(+0) tsAdvance:+39424/+60189/+64768, f:0
/dev/LimeXTRX0_trx0 Rx: 80.645 MB/s | TS:59999232 pkt:234372 o:0(+0) l:0(+0) dma:12588/12592(4) swFIFO:0
/dev/LimeXTRX0_trx0 Tx: 80.626 MB/s | TS:60062464 pkt:234366 o:0 shw:12586/12517(+69) u:0(+0) l:0(+0) tsAdvance:+47104/+61063/+64768, f:2
Total samples received: 60000256 signal amplitude: 0.164881 total samples sent: 60000256
/dev/LimeXTRX0_trx0 Rx: 80.645 MB/s | TS:69998592 pkt:273432 o:0(+0) l:0(+0) dma:25608/25616(8) swFIFO:9
Total samples received: /dev/LimeXTRX0_trx0 Tx: 80.663 MB/s | TS:70055680 pkt:273402 o:0 shw:25598/25540(+58) u:0(+0) l:0(+0) tsAdvance:+39424/+59810/+64768, f:0
69992448 signal amplitude: 0.156581 total samples sent: 69992448
/dev/LimeXTRX0_trx0 Rx: 80.620 MB/s | TS:80000256 pkt:312501 o:0(+0) l:0(+0) dma:38631/38636(5) swFIFO:1
Total samples received: 80000000 signal amplitude: /dev/LimeXTRX0_trx0 Tx: 80.626 MB/s | TS:80063488 pkt:312495 o:0 shw:38629/38563(+66) u:0(+0) l:0(+0) tsAdvance:+47872/+60980/+64768, f:1
0.173769 total samples sent: 80000000
/dev/LimeXTRX0_trx0 Rx: 80.645 MB/s | TS:90003456 pkt:351576 o:0(+0) l:0(+0) dma:51656/51660(4) swFIFO:1
Total samples received: /dev/LimeXTRX0_trx0 Tx: 80.651 MB/s | TS:90068992 pkt:351579 o:0 shw:51657/51584(+73) u:0(+0) l:0(+0) tsAdvance:+40192/+61090/+64768, f:0
90005504 signal amplitude: 0.162127 total samples sent: 90005504
Rx0: packetsIn: 390624
/dev/LimeXTRX0_trx0 Tx: 73.301 MB/s | TS:100056064 pkt:390591 o:0 shw:64661/64661(+0) u:0(+0) l:0(+0) tsAdvance:+32512/+59499/+64768, f:0
StopStreaming
Tx Loop totals: packets sent: 390591 (0x0005F5BF) , FPGA packet counter: 390591 (0x0005F5BF), diff: 0, FPGA tx drops: 0
