Yesterday I successfully run dualrxtx example code in limesdr using visual studio 2013. In code i changed frequency from 1ghz to 2ghz then i compile and run code on LimeSDR using visual studio 2013. code successfully burn in limesdr but when i disconnect it from host processor all code gone now i want that my could must retain in limesdr after disconnect from host processor so could you plz tell me what changes should i make in code so that code retain in chip after disconnect.It would be great if you help me with this problem
Hi @random,
Dualrxtx example runs on PC. You do not “burn” it to the LimeSDR-USB board. Hence if you disconnect LimeSDR-USB board from PC, then all the data transfers will be over.
