Ok, so a bit closer on using gnuradio-companion. I’ve managed rebuild the gr-osmosdr stuff from source, and I’ve monkey patched them into the right places so that now when I add the osmocom source to my flow with the soapy=0:device=lime device name it finds the LimeSDR. Not getting any data though. This is what I do get:
linux; GNU C++ version 5.3.1 20151219; Boost_105800; UHD_003.009.002-0-unknown
Using Volk machine: avx2_64_mmx_orc
gr-osmosdr v0.1.4-98-gc653754d (0.1.5git) gnuradio 3.7.9
built-in source types: file osmosdr fcd uhd miri hackrf bladerf rfspace airspy soapy redpitaya freesrp
-- Make connection: 'LimeSDR-USB [USB 3.0] 9062A00CE0F12'
-- Estimated reference clock 30.7196 MHz
-- Selected reference clock 30.720 MHz
-- Device name: LimeSDR-USB
-- Reference: 30.72 MHz
-- Init LMS7002M(0)
-- LMS7002M cache /home/cmcmanis/.limesuite/LMS7002M_cache_values.db
-- Ver=7, Rev=1, Mask=1
-- LMS7002M calibration values caching Enable
CGEN: Freq=80 MHz, VCO=2.56 GHz, INT=82, FRAC=349525, DIV_OUTCH_CGEN=15
M=156, N=3, Fvco=1040.000 MHz
16: FF AF AA
16: AA AA 3C
phase: min 26.0; max 197.3; selected 111.6)
M=182, N=7, Fvco=1040.000 MHz
16: AA 5A 75
16: AA 52 D5
phase: min 10.4; max 176.5; selected 93.5)
16: FF AF AA
16: A9 AA 7C
16: 77 9D 3B
16: 2A DC 7D
16: AA 52 D5
phase: min 15.6; max 176.5; selected 96.1)
-- Rx Filter calibrated from cache
-- Tx Filter calibrated from cache
phase: min 5.2; max 360.0; selected 182.6)
FATAL: std::bad_alloc
Trying to fill up 1 missing channel(s) with null source(s).
due to gnuradio bug #528.
