- Can I expect lower latency when using Linux instead of Windows?
- At 55MS/s in 12 bits dual channel I can properly receive using
latency="0.035"
on Windows. Anything lower than that doesn’t work well. Could switching to Linux help? - What’s the minimum latency I should expect in RX, ie roughly when I receive the samples on the host computer VS when the block was created in the FPGA?
