I there any guide for building mcu firmware? With recent problems with calibrations I wanted to modify the code to narrow its origin. From project files I assume it is Keil C51 project. However Lime Microsystems is not available as vendor in default Keil installation. I there any support package available?
Keil project file updated to use Generic/8051(All variants) device, should not need any support packages anymore.
While modifying code be sure not to go above 16384 bytes of const+code memory.
old chip version had 8KB, latest version has been increased to 16KB. The Datasheet might not have been updated.
That’s good news. That might also explain why I readout different chip mask from register 0x2f.
Can sdcc be used to compile this code?
