My setup:
System: Ubuntu 22_10(kinetic) with all updates
Python: python3/kinetic,now 3.10.6-1 amd64
Driver: gr-limesdr (build from source)
LimeSuite: limeSuite (build from source)
GnuRadio: gnuradio (build from source)
Radio: LimeSdrMini 2.0
there is a problem with the LimeSuiteSource(RX) Block,
it produce no streaming data.
If I switch to the SoapyLimeSDRSource Block all works fine.
After some analysing, I have seen that in the module ConnectionFT601.cpp
the function WaitForReading always falls into timeout after 1 Sec.
This is, because the libusb_fill_bulk_transfer produce no data.
With the SoapyLimeSDRSource Block the function WaitForReading
terminates correct because the callback has reportet a LIBUSB_TRANSFER_COMPLETED.
Has anybody an idea what goes wrong and where I must search for the problem?
Thanks
