Hi All,
I see a lot of FM tranceivers in GNU Radio for LIMESDR.
However, I could not find a single working PSK transceiver in GNU Radio for the LIMESDR.
Any help?
I don’t think there is anything dedicated to digital modes.
However it can be done by using SDRAngel and Virtual Audio Cable to connect to a program such as Fldigi.
I meant a simple GNU Radio project that is connected to the LIMESDR board using osmocom source/ sink.
Basically what you are talking about is an SSB transceiver that has a digimode front end.
So first you need to find a working SSB transceiver block and then build a digital conversion front end for it.
I’ve not heard of anything in GNU Radio that does the digital stuff like that but you can again use Virtual Audio Cable and a program like Fldigi on a GNU Radio SSB transceiver block to get there as well.
BPSK is called a mode but it is in reality more an encoding transmitted over SSB (or AM, or FM).
Take a look here:
And for a few more this search finds a lot of em:
https://www.youtube.com/results?q=gnuradio+bpsk&sp=UBQ%3D
Thanks for the info. However, I was hoping for an example that works with LIMESDR- Osmocom Source/sink.
All the examples use USRP or other devices.
Just replace the sink/source with the right one, that I do believe is how it is done.
What you need is just finding the block in gnuradio.
I successfully transmit txt file using bpsk, gmsk and qam.
I even tried to transmit real-time camera video, by using tcp sink/source and connecting together with opencv.
Thanks for the insight. However I always see TX no TX/RX in bpsk,qpsk, qam. Would you kindly share your application?
I don’t know what do you mean by TX or TX/RX, usually I see that in uhd sink instead of bpsk or qpsk blocks.
Here is a video I took when I was transmitting through gmsk. bpsk and qam is similar just replace the block and it should be done.
Any update on a BPSK transceiver example?
