Hi everyone,
I’m having the following error when using limeOEM --test
pi@cm4-dev bin % ./limeOEM --test
Board serial number: 0 (0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 )
=== LimeSDR-XTRX OEM Test ===
=== PCIe Reference clock ===
results: 19109; 20671; 22233
=== PCIe Reference clock - PASSED ===
=== VCTCXO ===
Count : 2606143 (min); 2606172 (max)
=== VCTCXO - PASSED ===
=== GNSS ===
=== GNSS - PASSED ===
=== LMS7002M ===
Registers test
Registers test PASSED
External Reset line test
=== LMS7002M - PASSED ===
=== RF ===
->Init Done
=== TX_2->LNA_L ChA ===
=== TX_2->LNA_L ChA - FAILED (RF FAILED, expected(-8.00 dbFS @ 5.000MHz), got(-58.09 dbFS @30.720MHz)) ===
=== TX_2->LNA_L ChB ===
terminate called without an active exception
zsh: abort ./limeOEM --test
Using LimeSuiteNG at Git hash 8a5cfc6bdb
, and CM4 IO board as a host system with dtoverlay=pcie-32bit-dma
overlay. The firmware of XTRX is the one it came with from CrowdSupply.
Is it a mismatch of firmware and software? Shall I try flashing an update? Or is the error is caused by something else?
The full device information:
pi@cm4-dev bin % ./limeDevice --full
Found 1 device(s) :
0: LimeXTRX0, media=PCIe, addr=/dev/LimeXTRX0_control, serial=0000000000000000
Expansion name : UNSUPPORTED
Firmware version : 1
Gateware version : 1
Gateware revision : 8
Gateware target board : LimeSDR XTRX
Hardware version : 0
Protocol version : 1
Serial number : 0
SPI slave devices :
FPGA
LMS7002M
Memory devices :
FPGA FLASH
GPS Lock:
GPS - Undefined
Glonass - Undefined
Galileo - Undefined
Beidou - Undefined
If it is a matter of firmware update, maybe someone can confirm the proper file an command for it? Would be good to avoid JTAG recovery if possible
P.S. The actual reason I’ve started looking into the self-test is because so far I hasn’t been able to see a signal from samples received from the XTRX. The data from XTRX is streaming, you can see a peak in FFT at the LO, but the rest is as if antenna is not attached and you’re looking at a noise floor.
