LimeSDR Mini LimeQuickTest failure
I have tested using the self-test tool, the board test failed:
->Start time: Tue Feb 4 16:12:31 2020
->Device: LimeSDR Mini, media=USB 2, module=FT601, serial=1D4258EDA1A25F, index=0
Warning: USB3 not available
Serial Number: 1D4258EDA1A25F
->REF clock test
Test results: 4295; 17492; 30689 - PASSED
Results : 6711060 (min); 6711213 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 07 1B 12 07 1B 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
SetFrequencyCGEN(61.44 MHz) failed
SetFrequencyCGEN(122.88 MHz) failed
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.45 seconds
Does this happen every time? Is it possible to try with a USB 3.0 port?
Yes, this happened everytime and i tried with USB 3.0 port.
@Zack anything to suggest?
Hi @Akki,
Post tester log when using USB3 here, please.
Hi @Zack
i sent the LimeSDR already for repair, all i have is the log (see above) that was created using the self-test tool
