I got my LimeSDR in early December 2017. I built the acrylic case and installed the board, but did not have a USB 3 cable to connect the device to my computer.
This week I finally received the cable and I cannot update the Windows 8.1 x64 default driver to the Myriad driver. This is the error I receive:
If I launch LimeSuiteGUI in Windows and choose Options > Connect, there are no devices in the list. It’s empty as shown here:
I also tried to connect to the LimeSDR in Ubuntu. After installing the PPA and all the software, LimeSuiteGUI does not list anything to connect to in Options > Connect. The screen is empty, same as shown above in Windows 8.1.
I have 2 solid green lights (closest to the USB connector) and 1 red flashing light (closest to the edge of the board, not the inner LED).
I have tried different USB 3 ports with the same results. I tried disabling driver signing, same failure. I also re-downloaded the driver. Same failure.
I’ve searched the forums and it seems like my LimeSDR may be defective. Do I have a defective device? Is there anything else I can try to get this set up?
