There is still something looking for UHD:
Err:22 http://ppa.launchpad.net/ettusresearch/uhd/ubuntu zesty/main amd64 Packages
404 Not Found
This error happened:
Setting up libhackrf0:amd64 (2015.07.2-11) …
rmmod: ERROR: Module hackrf is not currently loaded
I don’t know if these are related:
Segmentation fault (core dumped)
dpkg: error processing package python-openssl (–configure):
subprocess installed post-installation script returned error exit status 239
dpkg: dependency problems prevent configuration of python-ndg-httpsclient:
python-ndg-httpsclient depends on python-openssl; however:
Package python-openssl is not configured yet.
dpkg: error processing package python-ndg-httpsclient (–configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
E: Sub-process /usr/bin/dpkg received a segmentation fault.
I tested the installation procedure on a freshly installed 17.04 and it worked just fine. I got to the point where gqrx was running. There was a message regarding UHD because the UHD repositories are not available but that’s all.
I can’t help you with the errors you see there, but they do look very serious.
@joshblum I forgot about hackrf initially. Now I have updated it so you may want to rebuild soapyhackrf.
Also, an advice Larry… In case you are using Synaptic package manager, go to Settings -> Preferences and disable the “Consider recommended packages as dependencies” option. This will reduce the amount of unnecessary packages installed.
