Thank you very much for your message.
I am using the LimeSuite version: 22.09.1-myriadrf1~ubuntu20.04
I can add the message from the LimeQuickTest
->Start time: Fri Feb 10 22:00:25 2023
->LimeSuite version: 22.09.1-myriadrf1~ubuntu20.04
Gateware version mismatch!
Expected gateware version 2, revision 23
But found version 260, revision 0
Lime Suite - Myriad-RF Wiki
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=0009081C05C1302A, HW=0, GW=0.12
Serial Number: 0009081C05C1302A
Temperature internal ADC calibration failed
Chip temperature: 0 C
->FX3 GPIF clock test
Test Timeout. Last result: 0
->FX3 GPIF clock test FAILED
->Si5351C test
FAILED
->ADF4002 Test
Result: 0 - FAILED
FAILED
FAILED
->Clock Network Test FAILED
->Read data: 13 02 19 13 02 19 02
->FPGA EEPROM Test PASSED
RegistersTest() failed
->LMS7002M Test FAILED
SetFrequencyCGEN(61.44 MHz) failed
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 4.06 seconds
