- Commented both of them
- The connection was stable for 2 UEs I tested (simultaneously too). Though note I was using a small fan to cool the sdr. Perhaps you could try that if you are having issues maintaining connections.
Thanks for reply, like log on srsenb, is it normal : Preemphasis filter not active ?
root@ubuntu:/home/ubuntu# srsenb
— Software Radio Systems LTE eNodeB —
Reading configuration file /root/.config/srslte/enb.conf…
Built in Release mode using commit 45486b6e2 on branch master.
Opening 1 channels in RF device=default with args=default
Soapy has found device #0: addr=24607:1027, driver=lime, label=LimeSDR Mini [USB 2.0] 1D4C460D6ADDD9, media=USB 3.0, module=FT601, name=LimeSDR Mini, serial=1D4C460D6ADDD9,
Selecting Soapy device: 0
[INFO] Make connection: ‘LimeSDR Mini [USB 2.0] 1D4C460D6ADDD9’
[INFO] Reference: 40 MHz
Setting up Rx stream with 1 channel(s)
Setting up Tx stream with 1 channel(s)
[INFO] RX LPF configured
[INFO] Filter calibrated. Filter order-4th, filter bandwidth set to 5 MHz.Real pole 1st order filter set to 2.5 MHz. Preemphasis filter not active
[INFO] TX LPF configured
Any tutorial and demonstration on youtube for example will be also welcome. Recording using vokoscreen software for example. Thank’s for sharing
