New board: LimeRFE
@SimonG4ELI,
My crumbling memory is recalling that if you compile the LimeSuite app in Windows complete there is an ‘RFE’ menu selection at the top of the app that allows that LimeRFE controller to pop-up so you can set the amp up in any band where you plan to operate. So I don’t think I need to send you that app after all, you just click on that menu selection at the top of the LimeSuite application and it’ll launch the controller. That’s how you can tell if your LimeRFE is working or not (you actually connect to it using that side-app) and then select the major band of operation. Similarly, you’ll use the API calls in Chapter 9 to set the RFE up within SDRConsole and I’m pretty sure you’ll embed the features from the RFE’s API calls in your own code to set it’s band and mode of operation.
Hope this crumbling memory nugget helps you, Simon - thanks,
Thanks, also got a link to the source code I need. With luck I may be on QO-100 late next week, albeit with a tiny signal.
